Suspension Setup
Suspension Setup
Anyone run Hotchkis Springs with KYB AGX?
What about Hotchkis Springs and Bilsteins?
I know Sam Strano's setup with the Strano Springs and Koni shocks are the cat's meow but I'm looking at what other setups are out there that are also good.
LS1TECH Sponsor
I continue to sell other brands of springs, just for instances like this. I do think mine are better, but that doesn't automatically make everythign else junk.
Among the other brands are Hotchkis.... And H&R, Eibach, Vogtland's standard springs, and a bunch of cheap ones which I'd never use.
dragonrage is right in a sense. Bilstein's are not valved for, or inteded for lowering springs. If you hell-bend on Bilstein, than honestly the Hotchkis springs are a good choice because of the amount of drop and lesser spring rate--that gives the shocks the best chance to damp the springs in the best possible way. But sort of like saying running a moderate cam is better to use than a big cam if you are running stock valve springs....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
