Wilwood brakes/ LT1
Wilwood brakes/ LT1
what modifications if any are needed for the brake kit to work properly?
http://info.wilwood.com/BrakeKitsSub...e=Front%20Kits
If they are, then basically it comes with everything you need including a caliper bracket and stainless brake lines. You simply bolt it all on, bleed the brakes, and you're ready to rock.
If you are going to do this, you might as well flush the brake oil and get stainless lines for the rear brakes too.
