Shock dust cover
Shock dust cover
When replacing stock shocks/springs with Bilstein/hotchkis, do you reuse the the black dust cover? I can't seem to get it past the spring compressor jaw that protrudes to the inside of the spring. Maybe i just need to reposition the spring compressor.
Thanks for the replies...It seems it's best to position it inside the spring before you compress.
And if that's not enough I also found a torn boot on the tie rod end and possibly bad hub and I haven't even started the other side or the back yet.
