anyone run the threaded adjuster for bilsteins?
Old 05-01-2009, 11:23 PM
adam1803's Avatar
Default anyone run the threaded adjuster for bilsteins?
http://www.daymotorsports.com/produc...S-FOR-BILSTEIN
I don't need infinite adjustability as i don't really race, but would like some ride height adjustment. Im thinking of using the above kit with some bilsteins, was wondering if anyone has used it before.
Old 05-02-2009, 12:12 AM
99Bluz28's Avatar
Lightbulb
Those will not work.
The diameter is too small on those sleeves,our bilsteins are 2" diameter.You would need like a 52mm sleeve for it to work.
Look for threaded spring seat sleeves for 2" dia.shocks.
Old 05-02-2009, 01:49 AM
JDishong's Avatar
http://www.ground-control-store.com/...hp/II=21/CA=67
Old 05-02-2009, 04:02 AM
adam1803's Avatar
good to know, i hadn't measured yet obviously but i thought 36 and 46 were pretty standard.
I've seen the ground control kit, but its not worth spending that much to me right now.
Old 05-02-2009, 11:19 AM
ThumperNC24's Avatar
also, bilstein should not be used with lowering springs.
"coil overs" are not the best handling solution for our cars either.....
Old 05-02-2009, 01:38 PM
99Bluz28's Avatar
Thumbs up
IMO, I've had the G.C. setup, but just doesn't compare the the Global West setup!
http://www.globalwest.net/1993-2002_...usting_kit.htm
Quick Reply: anyone run the threaded adjuster for bilsteins?
