oops lowered without LCA reloc brackets, what now?
I had hotchkis springs and koni shocks installed on my 02 Z28, and only bought a adj panhard bar w/ the setup. I just found out I should have got LCA recloc brackets as well. I had an alignment done on the car after getting the springs, shocks, and phard bar installed.
Do I just buy some reloc brackets and go back to my shop to have them installed, or do I need to get adjustable LCA's and skip the brackets. I was thinking of upgrading the LCA's anyhow as the stock ones are getting old. Hope someone could clear this up. Thanks.
The brackets will help to realign the angle on your LCA due to the drop in height. You can still get them and put them in. If you get the bolt in brackets you can do it yourself. Its pretty easy. If you do decide to upgrade your LCA's then go adjustable. It will allow you more options if you mod further.
A few suggestions for you!
Hello
I have a few suggestions for you! I would look into a set of Lower Control Arm Relocation Bracket and a adjustable pan hard bar! The relocation brackets will gain back the traction loss and increase your traction performance that was lost when you lowered the vehicle and can be used with the stock lower control arms or aftermarket non adjustable control arms. And the reason why is suggested a adjustable pan hard bar is when you lower a vehicle it off sets the rear end and the pan hard bar will allow you to readjust the rear into the proper position! Below are a few links to show you what UMI Performance has to offer.
http://umiperformance.com/products.php?category_id=125
http://umiperformance.com/products.php?category_id=124
If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
Thanks
Brad
LS1Tech Premium Sponsor
You do NOT need LCA's or relo brackets after lowering.
If you like to launch and all of a sudden get a lot of wheel hop, relo brackets can help you adjust your LCA angle which typically has a curing effect on most people.
The angle of LCA's also has an effect on roll steer. Changing the angle of the LCA's due to lowering causes the rear end to point toward the way you turn "ever so slightly" in a high speed turn which isn't a bad thing in my racing situation. It probably keeps my car a bit more stable going around the turns.
It all depends on your application. But in any case nothing the slightest bit bad will happen to you with no relos.
