really bad squeak from passenger rear...
to me it sounds like the shock is squeaking from the back passenger side...
is there anything else it could be?... it squeaks quite loud when i do anything to move that area up and down, bumps, turns, etc...
what are my options here as far as replacing, unless theres a free way to fix it..?
would the fluid film stuff work here?
I just replaced my rear shocks a few days ago, my car was squeaking so bad that it was embarrassing. My car exhibited the exact symptoms that you describe. A good replacement shock that you might consider are the "KYB Gas Adjust", they are reasonably priced & they worked great for me...no more squeak & nice tight ride. I bought mine at RockAuto. Also, you might want to check your bushing...sway bar bushing,sway bar end-links,etc.
Hello
Like mentioned above! I would check to see what condition the bushings are in.
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
