View Poll Results: Which Sway bar
BMR drag bar
2
66.67%
Wolfe Roll bar
1
33.33%
UMI Drag Bar
0
0%
Hotchkis Adjustable Sway bar
0
0%
Spohn Chrome moly solid
0
0%
Voters: 3. You may not vote on this poll
Sway bar/Roll bar.. Vendors come in!
Old 10-26-2009, 12:01 PM
1998Chv37s's Avatar
Default Sway bar/Roll bar.. Vendors come in!
Looking to order one today. See what kind of deals i can get!.. Looking for a drag bar, roll bar is a little aggressive for it being my dd and everything, but im open to everything!
http://www.sevendeals.com/p-4036-spo...-rear-bar.aspx
http://www.hotchkis.net/9302_camarof..._sway_bar.html
Also the umi and bmr drag bars. and wolfe roll bar..
Those are some of the options. I dont really want to spend the 450 on the bmr but if its that much of a difference im going to do it the right way first!
car has bmr subframes, adjustable torque arm, k-member, m9, monster stage 3, 440rwhp.
I do plan on spraying it in the future.
Thanks in advance, austin
Old 10-26-2009, 12:53 PM
UMI Performance's Avatar
Hello,
A drag is OK on the street, it won't ride bad but it is stiff and we don't suggest flying into a turn with it. However since our bar does feature polyurethane bushings there is some give in and bar so it will work on the street.
Our bar is bolt in with welding recommended. You can bolt it on and drive it to the shop to have the little bit of welding done. We also have our bar on sale right now and they are in stock.
If you have any questions please ask. Thank you!
Ryan
Old 10-26-2009, 12:57 PM
1998Chv37s's Avatar
It will be going on a 9in and the brackets the go up to the axle tube the guy that had before me chopped them off
Old 10-26-2009, 01:00 PM
Our drag bar includes the new sway bar brackets so that is fine. If you buy a regular sway bar you will need to purchase brackets to bolt it to the rear end like these- www.umiperformance.com/2244-300
Hope that helps!
Ryan
Old 10-27-2009, 07:35 PM
1998Chv37s's Avatar
Thanks Chris! Your the only one to speak up and help! Just put my order in for your drag bar
Quick Reply: Sway bar/Roll bar.. Vendors come in!
