Alignment Tool
Old 11-16-2009, 04:50 PM
grldchz's Avatar
Default Alignment Tool
Does anybody know the Snap-On tool part # to adjust camber and caster on ls1 trans am's and camaro's?
Old 11-16-2009, 05:00 PM
SS SLP2's Avatar
tool would make the adjusting easy, but I did these cars for years with out the special tool, I just used a pry bar to move the lower control arm any direction which was needed to correct the caster /camber. If you jack up the car to the point where the front tires are only just toching the pad/street/turn plate or whatever the control arm is easy to move.
good luck,Johnny
Old 11-16-2009, 05:29 PM
grldchz's Avatar
yeah that's what I've been using for a while until i found out there was a tool made for that. but thanks for help.
Old 11-17-2009, 06:11 AM
toadzq8's Avatar
refer to it as a j-hook, do a search I got mine used for $30.00 at a online auction site
Old 11-17-2009, 06:05 PM
leadfoot4's Avatar
good luck,Johnny
While fundamentally true, having the tool makes it a LOT easier, quicker, and more accurate....
The tool is made by Kent-Moore, and the part number is J-38658
Quick Reply: Alignment Tool
