front height uneven
front height uneven
will bolting on the front sway bar endlinks with one side jacked up cause uneven ride height? I think I will go back and reinstall the end links with the car sitting level. right now the side that was jacked up is sitting about 1/2" higher.
LS1TECH Sponsor
Links should always be tightened with the car on the suspension (say on ramps...).
Yes, it can mess with the height a little.
__________________
thanks Sam. I'll get it on 4 ramps and loosen and retighten the endlinks.
The Konis are awesome! I have the 4/3's on my stock 1LE springs. It sits a little high for my taste, after being at DMS ride height, but the ride/handling is great. almost exactly 1" higher then the DMS ride height. both have/had the hose mod and the fronts are now on the lower perch.
LS1TECH Sponsor
Just wait until my springs get there.
I'm glad you like your Koni's, well worth it--don't you think?
__________________
