Brake Pedal Way tooo hard after brake booster hose was removed
Old 12-15-2009, 08:39 PM
jattgunman's Avatar
Default Brake Pedal Way tooo hard after brake booster hose was removed
So I had to remove my brake booster hose and accidentally pressed the brake pedal and now I believe air got sucked into the brake lines...
We just bled all four calipers and the pedal travel was normal, but now its stiff again(zero travel) and I didn't even drive her yet.....What can cause this?
Old 12-15-2009, 09:02 PM
ThumperNC24's Avatar
if you didn't open the master cylinder you didn't get air in the lines. You can't get air in the lines via the booster, totally different systems.
you let all the vacuum out of the booster (well, you let pressure in, but whatever). Place the hose back on and start the car up, push the pedal a few times and it should draw vacuum and go back to normal.
Old 12-15-2009, 10:12 PM
jattgunman's Avatar
I tried turning the car on and pumping the pedal but it just doesn't want to soften up at all....And I also made sure that the brake booster hose is on nice and tight
Old 12-15-2009, 10:37 PM
jattgunman's Avatar
ok i figured out the problem! and it sucks!!! I accidentally pinched off the brake booster hose on the back of the intake manifold while replacing the knock sensor..looks like i have to take it off again...p.i.t.a but at least I know what it is
Quick Reply: Brake Pedal Way tooo hard after brake booster hose was removed
