weight of hollow 35mm front sway bar?
Old 01-23-2010, 01:33 PM
therealcreeper's Avatar
LS1Tech 10 Year
Default weight of hollow 35mm front sway bar?
just picked up a 35mm front bar off of a bilstein ultra car. definitely feels lighter than my solid 35mm UMI, but it's double the weight of my stock 30mm bar.
anyone know the approximate weight of a hollow 35 or for sure if the bilstein firehawk cars got hollow or solid bars? one source online says hollow, the other says solid.
thanks
Old 01-23-2010, 06:15 PM
ssam98's Avatar
if it is from slp I think it is solid. my buddy had the slp 35mm put in from slp and it was very heavy.
Old 01-23-2010, 10:55 PM
LS1Tech 10 Year
yeah it still weighs quite a bit but turns out it is actually hollow
info here:
http://www.firehawkowners.com/option...l/1835135.html
also confirmed by sam strano and others in posts i found while searching
Old 01-24-2010, 01:19 PM
ssam98's Avatar
good find.
Old 01-24-2010, 08:36 PM
LS1TECH Sponsor
Sam Strano's Avatar
so what does it weigh? I know what mine weighs, and it sounds like theirs is a lot heavier. My bar in a box (a big box 56x21x3") with all the endlinks and bushings and clamps is 20 pounds out the door. The bar itself is about 15 pounds which is about 3 pounds more than stock 32mm, about 5 more than a 30mm. If your bar is really double your stock bar... that's surprising for a hollow bar unless it's got a wall thickness that is just stupid thick.
__________________
Old 01-24-2010, 09:17 PM
LS1Tech 10 Year
just reweighed them (bathroom scale):
30mm with mounts, bushings, and endlinks: 12lbs
35mm with mounts, bushings, and endlinks: 19.2 lbs
i thought the stock bar came out to 10lbs last time which is why i rounded to double. i guess either the scale isn't accurate or i wrote it down wrong.
