One problem with adj. shocks!
Old 02-24-2010, 07:32 AM
ta-stanger's Avatar
Default One problem with adj. shocks!
If your car is lowered you can't get under it to adjust them umless you don't eat much and have really long arms! So to a lift I go!!
Old 02-24-2010, 08:00 AM
1BADTALS1's Avatar
a lift? just put a 2x4 on the ground and drive on it. just need a 6-8 inch section for each fron tire.
Old 02-24-2010, 09:14 AM
mikedamageinc's Avatar
Which shocks??
For the Koni's just open the little flap in the back and turn. For the fronts I stick a small allen wrench behind the coil and turn the disc thing.
The only thing I dont like is you can't adjust them by an in cabin switch!
Old 02-24-2010, 09:56 AM
EW1
EW1's Avatar
I have KYB AGXs and all I have to do is fully turn the wheel left or right and reach around the tire to adjust them.
Old 02-24-2010, 12:40 PM
ta-stanger's Avatar
I got KYB's to, but with my tires which arn't that big( 275 f and 295 r) there ain't a man alive who can slip his hand in there. If you can I bet you never have to buy snacks out of a vending machine!
