What calipers/rotor combo will clear prostars?
I started grinding on the front calipers the other day, and i still have ALOT to go, so i was wondering which caliper/rotor kit/combo will clear prostars without issues. Figured it might be better in the long run, if not i will just get some spacers and continue to grind and grind.
thanks for the input!!
Are you talking fronts of rears? For the fronts, I didn't have to grind at all. I just used a 3/16" spacer and called it a day. The rears are a little different considering you have to worry about the studs. Longer ARP studs with a spacer can help avoid some of the grinding.
