instaling qa1 coil overs on the front
i removed the strut tops from my stock set up today, do i need to put the black cover back on? also there was like a small spacer under the black cover would i reinstall that.
thanks for the help
thanks for the help
are you referring to the dust boot when you say black cover??... they keep dirt, water, debris, etc from getting into the strut body so i would put those back on... and the spacer, if i'm understanding correctly, you will definitely need... it provides a flat surface for the bottom of the strut mount to rest on
