Brakes squeal
Old 04-08-2010, 08:11 PM
Drew24's Avatar
Default Brakes squeal
Did a brake job about a month ago and ever since then the brakes scream like crazy and its only getting worse. The caliper is on right and everything seems fine but when i brake or turn to hard there is a screaming noise im stumped what could it be.
Old 04-08-2010, 09:28 PM
therealcreeper's Avatar
did you break them in properly?
Old 04-09-2010, 12:56 AM
crazydavez28's Avatar
what pads did you buy? I did my rear brakes last fall and every time i turn left (only left too) it sounds awful. I used the semi-metallic from o'reilly's. I'm seriously considering buying the cheapest organic brake pads again b/c they never squealed.
Break them in?
Old 04-09-2010, 10:07 AM
HotWS6's Avatar
Best way to go to fix this issue is to use the AC Delco pads and rotors, will never squeal
