Trying to bleed with ABS InOp light on.
Old 04-15-2010, 09:04 PM
S2K
S2K's Avatar
Location: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
Default Trying to bleed with ABS InOp light on.
So I have had my ABS light on for quite a while. I know its a fault in the rear channel. Anyways, I ended having to undo the brakes at the rear to drop the rear end. Now I need to bleed them, but I've heard not to do it with an ABS light on.
Can I just take an ABS fuse out or disconnect the rear sensor at the differential then bleed? or just try to bleed anyway?
Anyway around this? I need to drive the car to a shop to get the exhaust welded.
Quick Reply: Trying to bleed with ABS InOp light on.
