c5 z06 brakes and torque thrust 17 by 9 M wheels clearance??
I thought read that these cleared no problem and the torque thrust 2 required spacers. So got these bolted on my car.It seems that am getting some noise and not 100% sure but it might be caliper to front wheel contact.
Did anyone else have any problem with TTM 17 by 9 and the c5 z06 swap?
I used umi bracket adapter,corvette caliper brackets for my conversion.
Simple enough just had to cut lower ear off stock spindle or hub.
So do they make a spacer that will give more clearance and will it affect anything much ,wheel bearing life,etc???
Or do I just have to grind down corner of caliper with dremel or something.
