SLP SFC questions
SLP SFC questions
ok so i just got me some used bolt on slp 3 point boxed subframe connectors that were never put on his car
so i was wondering if these reuse the stock bolts and if not what do they use?
also does anyone have the instructions for them? one seems different from the other and i need to kno which side go where and stuff
any other info you have on them would be great aswell!
thanks!
thanks!
i can't see either side going in more than one way (especially being bolt-in)... should be pretty obvious if you put it up under the car. from what i remember i think you reuse the stock bolts, though i have seen aftermarket bolts sold
they should've come with a mounting hardware kit consisting of some bolts & mounting plates. The mounting holes line up with holes already in the sub frame support. Now you will reuse the bolts that hold the trans mount in place. Aside from the 4 trans mount bolts, it's all new hardware.
