Skating around, need opinions
Old 05-29-2010, 03:05 PM
mr_biscuitz's Avatar
Default Skating around, need opinions
Been playing with my new set-up for a couple months now and everyonce in a while the car will skate around pretty bad above 100mph. My question is what can i do to help the problem? A little on my set-up............. 28x10.5 slicks (stiff sidewall) and tubes, rear 1 inch spohn solid rear sway bar, qa1's on all 4, I have all suspension but didnt' think the rest mattered all that much for the problem Im having.
Old 05-29-2010, 03:06 PM
oh yeah it doesnt do it all the time and air pressure is at 14lbs
Old 05-29-2010, 03:43 PM
BAMALS1's Avatar
How new/old are the tires? Could be the tires you are feeling, or I would check all of the suspension components for looseness, like the panhard bar.
Old 05-29-2010, 03:45 PM
BAMALS1's Avatar
Also, try to run as much air as possible 18-22 psi in the rear tires until it starts to spin. That will help out too.
Old 05-30-2010, 02:41 PM
JD_AMG's Avatar
Over sized rear swaybar, + shitty shock dampening + drag tires.
Probably also have aftermarket LCA's that are binding...
Old 05-31-2010, 09:15 AM
tires are two weeks old and tire pressure was around 14 hot, checked all parts for being loose and couldnt find anything.
Quick Reply: Skating around, need opinions
