Bleeding question for lt1
Old 06-02-2010, 05:47 PM
97 Trans Am ws6's Avatar
Default Bleeding question for lt1
just finished installing new drilled and slotted rotors all the way around and i ended up going with hawk pads. I bled the brakes like you would normally on most cars and took it for a drive and it seems to be a little stiff, is this normal for these cars? If not am i missing a step?
Old 06-02-2010, 07:41 PM
bore.me's Avatar
mine's stiff
Old 06-02-2010, 08:28 PM
99345hp's Avatar
stiff doesn't mean a bleeding problem. You might have had a little bit of air in there before, and now that all the air is gone the pedal is stiffer.
