Front struts keep busting
Old 07-22-2010, 12:02 PM
69gto96z's Avatar
Default Front struts keep busting
For some reason, my car keeps busting the bottom bushing out of the front strut, where it mounts to the LCA. Has anybody ever heard of this happening? I can't find any info on it. The struts usually last about a month before doing this. They are just parts store factory style struts. After they bust, they squeak like crazy. I do not have the money to buy high dollar struts, but was thinking I might be able to press the bushing out and put a poly one in there, it might hold up better. Something along these lines, these are for shocks, not struts btw. http://www.energysuspension.com/univ...-bushings.html
Old 07-22-2010, 12:35 PM
libertyforall1776's Avatar
What kind of shocks are you using? Might want to get some with a lifetime warranty...
Kinda sounds like an alignment problem or you have some bent part -- maybe a prior accident?
Old 07-22-2010, 11:46 PM
Prin's Avatar
Mine is doing the exact same thing. I am getting tired of it! I had my alignment check and it was dead on. I dont know what to do now..
Old 07-23-2010, 02:17 AM
69gto96z's Avatar
They are lifetime struts from Autozone. I know the alignment it off. I replaced the spindles thinking they could be bent, and it did the same thing after doing that and getting it aligned. I would like to do a complete tubular front and get some nice struts, but can't afford it.
Old 07-27-2010, 02:37 PM
BMR Tech's Avatar
Pretty sure the front shocks are bottoming out.
Have had customers in the past with the same issue and that was he end result.
Need to raise the car up to give the car some travel to work with.
Quick Reply: Front struts keep busting
