It's hooking......Thanks UMI!!!
I already had panhard bar, SFC's and LCA's with 305/35 ET streets and the car wouldn't hook for ****. Talked with UMI and they had me add QA1 rear shocks and relocation brackets. I dropped 3-4 tenths on my 60' times.
When it would hook (which wasn't often) I was in the 2.05-2.1 range. Now I'm in the 1.75-1.8 range. I have the QA1's set at 4 clicks from the softest and I'm in the bottom hole on the relocation brackets.
nice, i was wondering because im in the 1.7-1.8 range now and i have 50/50 shocks and a umi ta and no relocation brackets. im going to raise my ta to the upper hole on the crossmember and try that next after i replace my fender and side skirt after i had a tire lose its tread during a run. im hoping to get into the 1.6s since i have a much bigger stall now i havent been able to reach them yet. im also cam only at the moment.
QA1 Rear Shock
If you have any questions please ask. Thank you!
Ryan
