Squeaky Afcos?
Old 08-18-2010, 09:26 PM
tscheu5452's Avatar
Default Squeaky Afcos?
I have Afco 3875R single adjustables in the back and they squeak constantly over every little bump. What could be the cause? Is this something I'm supposed to expect?
Old 08-19-2010, 03:41 PM
johnpate01's Avatar
Are you sure it's not a rear suspension bushing? Did it start when the new parts were installed? I had a similar problem and it ended up being LCA bushings that needed to be greased and retightened.
Old 08-19-2010, 09:43 PM
tscheu5452's Avatar
I will check it out. It seemed to start a couple hundred miles after the new parts were installed. I can hear it a lot inside the car like it's coming from the top of the shock mounts.
