Spohn A-Arms : Wider than stock?
Old 08-30-2010, 02:16 PM
Giggity's Avatar
Default Spohn A-Arms : Wider than stock?
I'm thinking about ordering custom wheel spacers as part of my whole 2010 brake caliper project. I figured to make sure I have plenty of wheel to caliper clearance I would go as a big as I can while still keeping the tire under the body.
I have some Spohn upper and lower a-arms I plan on installing at a later date when I save up enough money to do my Konis and Stranos.
My question is, should installing the tubular a-arms have any effect on the width of the front end at all or should it be an exact match to stock? If I spend the money on custom spacers I would hate for my wheels to stick out an inch past the body when I finally put the a-arms on!
Old 09-01-2010, 11:38 AM
fisherz28's Avatar
Im not sure about the uppers but i know the lowers are adjusted to factory specs before they are shipped out. I would assume the uppers would be the same.
Old 09-01-2010, 06:54 PM
Giggity's Avatar
Thank you for the reply
Old 09-02-2010, 11:25 PM
sjsingle1's Avatar
my uppers seemed no bigger than the stockers when i put them on
Quick Reply: Spohn A-Arms : Wider than stock?
