SJM ABS Delete
SJM ABS Delete
I'm looking at deleting the ABS from my 97 this winter but the SJM website has me a little unsure about the Linelock option.
It gives me the option to select a Linelock or "no thanks, I have my own", which suggests to me I have to use one with their kit.
I don't have a linelock and as I'm not a drag racer don't really have a need for one, so can I run the SJM kit without a linelock?
You MUST have a linelock with there kit, it will not work without one, they're lines are bent for it. I'm about to go install mine and hopefully do a writeup since there isn't one in existance
You can always jsut bend your own lines to a t fitting if you dont want line lock.
There really isnt a need for a write up, after doing this earlier this summer its really easy. But off old line fittings, intsall T fittings, run to supplied lines/selenoid/proportioning valve. bleed brakes. drive car
