new suspension 97'
Old 10-25-2010, 05:31 PM
94ss06gxp's Avatar
Default new suspension 97'
looking at eibach sportline springs, possibly bilstien shocks??? not too up with the F Body suspension game, any recommendations?? the car will be used for summer fun and hit the track once in a while, i wanna go pretty low but i will also be running 18x10.5's in the rear 17x9.5's in front (getting the rims in november). if you guys could recommend some somewhat budget friendly setups it will be awesome!!!! thanks - Levi
Old 10-25-2010, 07:52 PM
99FormulaM6r's Avatar
If you just want to go low, the Sportlines are a good choice. However, if you want good handling and a comfortable ride, there are MANY better choices out there. Sportlines are notorious for basically making you ride on the bump stops all the time. There are much better lowering springs out there that will give you a drop of around 1.25" if that's enough for you. Some Strano or BMR springs with Koni's (or Bilsteins if you can't swing for them) will ride and perform MUCH better.
Old 10-25-2010, 09:12 PM
94ss06gxp's Avatar
thanks!! i will check those out. i would like to stay around the $700 range
Old 10-25-2010, 10:57 PM
Strano's and SLP Bilsteins would be right around $700 then. If the drops enough for you, they'll be worlds better in ride/handling than the Sportlines. If you can afford it tho, the Koni's would be a better choice, but for $700 that wouldn't happen, lol.
Old 10-26-2010, 11:39 AM
LS1TECH Sponsor
Sam Strano's Avatar
$679.99 plus the shipping on the shocks. So as long as you aren't in some far out corner of the world, $700 should cover that setup. http://www.stranoparts.com/partdetai...D=90&ModelID=7
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-26-2010, 02:47 PM
94ss06gxp's Avatar
, my buddy has the strano/koni setup on his t/a and i really like the drop and the way it handles for sure!!
Old 10-26-2010, 02:49 PM
94ss06gxp's Avatar
thats prolly what i will go with!! thanks guys!!!!
