Will C5 brake conversion brackets fit C6 Z06 calipers? UMI
Old 12-30-2010, 07:54 PM
ssjason232's Avatar
Default Will C5 brake conversion brackets fit C6 Z06 calipers? UMI
So i have a set of UMI c5 brake calipers laying around, and im about to pick up a set of C6 Z06 calipers. I know the calipers will bolt up, but my question is about the rotor size.
Is it possible to use the C5 bracket with the C6 Z06 calipers AND the 14 (335mm) rotors.
-or-
Will i have to use the C5 13" rotors? and are the 13" C5 rotors compatible with the Z06 calipers
btw, i already have 18" wheels, so thats not an issue.
AND, ive looked through the search features, nobody really covered this.
Old 12-30-2010, 09:25 PM
Kleeborp the Moderator™
MeentSS02's Avatar
From what I understand, if you use the conversion bracket with the C6ZO6 calipers, you have to use the C6ZO6 rotor (which is 14" I think). I'm sure someone will correct me if I'm wrong.
Quick Reply: Will C5 brake conversion brackets fit C6 Z06 calipers? UMI
