Indepedent Rear Suspension (IRS) in a 4th Gen
Old 05-03-2012, 08:14 AM
  #41
lees02WS6's Avatar
Originally Posted by libertyforall1776
A neat addition to this thread would be a compare and contrast of a Watts Link vs IRS Camaro...
For me, that would mean lending out the car to someone that can actually drive. In addition, getting the wheels, tires, and brakes as similar as possible so you are comparing the watts/live axle vs IRS.
Of course you can buy the Watts link for $650, bolt it on in an afternoon, and it won't throw you in to some custom class. The IRS on the other hand, well, see page 1.
Old 06-12-2012, 08:22 PM
  #42
My6speedZ's Avatar
Wow great post Lees02Ws6, nice to see people still posting really thorough and informative post
Old 06-13-2012, 05:41 AM
  #43
Driver_10's Avatar
I'm in the middle of doing this swap right now. My swap is a bit more invasive since though. Iv'e already cut out the wheel-wells and have removed about 50lbs of metal since I started.
I'm going to build a square tube cradle to connect the IRS mounts to the roll cage. Im also going to install a fuel cell since the space for the stock tank is being used for the cradle.
It should be fun.
Old 06-13-2012, 08:07 AM
  #44
Drokkers's Avatar
wow is all i have to say.
Old 06-26-2012, 09:28 PM
  #45
szalkerous's Avatar
This thread has me with stars in my eyes. The only red flag is the classification change. I autocross my car, and I wouldn't want to shoot my foot over this kind of swap...
Old 06-27-2012, 09:25 AM
  #46
Copy & Paste Moderator
VIP1's Avatar
I've added this to the Suspension & Brake Tech FAQ:
https://ls1tech.com/forums/suspensio...-tech-faq.html
Old 06-27-2012, 05:53 PM
  #47
kyoytey1693's Avatar
Good idea!
Old 06-28-2012, 10:22 AM
  #48
lilpb1's Avatar
Anyone have detail pictures of where everything that is need to be welded. I contemplating doing this install since i came across a Dana 44 really cheap.
Old 06-28-2012, 09:14 PM
  #49
HoLLo's Avatar
I want to see a video under the car doing a donut!
Old 06-28-2012, 09:58 PM
  #50
DBL_TKE's Avatar
Why isn't this a stickey?
Old 06-28-2012, 10:20 PM
  #51
VIP1's Avatar
It is. Take a look at my post #46.
Old 06-30-2012, 01:11 AM
  #52
Driver_10's Avatar
Ill be sure to take measurements.
Old 07-01-2012, 04:32 PM
  #53
Driver_10's Avatar
I am broke as a joke for the time being, but I if get a good HD camera, Ill be sure and make a vid.
Old 07-02-2012, 05:41 PM
  #54
99_orange_SS's Avatar
If I can get my hands on a camera I'll do it soon for you
Where you are going to weld all depends on how you want to install the differential/batwing/spindles. To be very basic though you will be welding to the primary frame rails. The factory cross supports over the stock axle are cut out and you weld in your new brackets there. There are many options to how you mount the spindle/front differential mount though.
Old 07-02-2012, 09:11 PM
  #55
van454's Avatar
This is one of the best threads I have seen on this site. So many questions answered. Now how about other IRS types? What about 5th gen/G8 type IRS? Has anyone looked at that as an option?
Old 07-03-2012, 06:26 PM
  #56
To be honest the reason no other rear assemblies have been considered is because of weight and design of the systems. Both setups you mentioned above are bulkier, heavier, and will not provide a large improvement over a C4 properly setup to accustom someone's goals. The only next step for improvement will be C5/C6, which I will be working on within the next year to replace my C4 setup. Once the new setup is in I will make a kit for the C5/C6 rear setup, that'll be a year or so down the road; keep your eyes peeled for updates. I know Lee is currently working on one for the C4 and he will keep everyone posted on that.
Old 07-03-2012, 07:21 PM
  #57
Cape T/A's Avatar
That is amazing, very nice work guys, and you all get serious respect from me for attempting/doing a conversion like this!
Old 07-05-2012, 01:36 AM
  #58
lilpb1's Avatar
I've been looking around for an easier option and came across this and its meant for a C4 and has all the mounting points already set up. As a bonus i think it might be possible to extend the frame to connect the rear with the front K member for more chassis stiffness and less body flex.
Will be a reasonable option? The kit is only $250 which i think isnt bad.
[IMG][/IMG]
Old 07-05-2012, 06:30 AM
  #59
Driver_10's Avatar
I was looking at the cradle as an option myself... After looking at it long enough, I came to the assumption that it wasnt worth the trouble to entirely "back-half" the car to fit this cradle into it. Unless you've got some decent metal fab equipment to make another bulkhead, I wouldn't try it.
Also not too happy about the fact that the trailing arm mounting points arent adjustable.
Now maybe if you bought one and used it as a "jig" to build one more suited to the underside of the F-body, or just chopped and modified this one to fit, then maybe buying one is a better idea.
Old 07-05-2012, 11:37 AM
  #60
lees02WS6's Avatar
Back halfing would be more difficult, even if you got one for a fourth gen. Using a subframe for a different car would increase the difficulty because the rails wouldn't match exactly the location of the existing structure, and might interfere with other items, like the fuel tank for example.
There are advantages, ease of install just doesn't seem to be one of them.
To me, a jig that squares the rear end up, a datum on the car that's square to the frame, and a four post lift would be the easiest method to do the install.
Quick Reply: Indepedent Rear Suspension (IRS) in a 4th Gen
