NEW-J&M Panhard Bar Rod w/ Polyurethane Bushings, "On-Car" Adjustable (82-02 F-BODY)
Old 09-27-2011, 01:04 AM
COSPEED's Avatar
Thumbs up NEW-J&M Panhard Bar Rod w/ Polyurethane Bushings, "On-Car" Adjustable (82-02 F-BODY)
J&M Products has produced the strongest turnbuckle style on car adjustable panhard rod on the market. This panhard rod is a direct replacement to your weak, factory stamped rear panhard rod. This panhard rod is made using high strength 1.25" OD steel tubing with CNC machined ends and laser cut main tubes for the ultimate in fit and finish. J&M’s panhard rod adjuster is made using the same high strength Forged 4340 Chrome-Moly that all of our rod ends are manufactured from making this a very strong piece.
The forged turnbuckle we use features formed rolled threads (not cut threads like the competition) making it a true high strength piece. Once the threads are roll formed the part is clear zinc plated and heat treated to the same strength as a grade 8 bolt. A Performance panhard rod is one of the first parts that should be done on the 3rd or 4th generation Fbody. These direct bolt-on replacement parts will minimize wheel hop, improve straight line traction, and improve cornering, while lowering track ETs and helping your launch launch straighter.
Panhard Rod Features:
--1.25” x 0.095” DOM Steel Tubing
--1045 Steel Threaded Tube Adaptors
--High Strength Heat Treated 4340 Chrome-Moly Adjusting Turnbuckle.
--High Frequency Pulse Welded Construction with Rosette Welds on the Bung Side for Extra Strength
--Grease Fittings For Easy On Car Maintenance Of The Energy Suspension Poly-Urethane Bushings.
--Designed for Proper Use of the OEM Hardware
--Standard Red or Black Powder Coating for a Great Looking Long Lasting Finish
--Improves Responsiveness and Control
--Fully Adjustable On the Car
http://www.coloradospeed.com/index.php?main_page=product_info&cPath=2902_626_10 2&products_id=19473
Old 10-04-2011, 09:55 PM
KTK Z28's Avatar
placed an order for one as well as some other goodies. Thanks for your tech support.
Old 10-05-2011, 11:29 PM
ANTICOP RAM AIR's Avatar
not bad price for on car adjustment... Ill wait and see how they work out...
Old 04-17-2012, 11:39 AM
COSPEED's Avatar
Just an FYI, J&M will be coming out with an on-car adjustable LCAs with poly bushings on both ends with the adjuster closer to the end than on the center which is considered a weak point when putting the adjuster in the center like that. Stay tuned!
Quick Reply: NEW-J&M Panhard Bar Rod w/ Polyurethane Bushings, "On-Car" Adjustable (82-02 F-BODY)
