Eibach sway bar bushings/brackets?
Just grabbed a set of Eibach front/rear sway bars for $125 shipped. I'm quite aware of how some feel the rear bar is too big compared to the front and causes some handling issues, however for $125 I figure why not try them out. So I don't want this thread to turn into that, they're on there way and it's a done deal.
What I do need to know is since I bought the bars only i need the part numbers and where to buy the bushings, brackets, ect to install them. Thanks!
Hey ECU.
We have your necessary installation products.
http://www.umiperformance.com/catalo...roducts_id=444
http://www.umiperformance.com/catalo...roducts_id=463
These may or may not be your sizes but I just wanted to show you an example.
If you call and talk to Jerry he can also provide end link part numbers.
As for the rear to front roll couple distribution, if the rear is too big and makes the car over-rotate we can discuss how to remedy that. I checked Eibach's site and it seems they may have two settings on the rear. If so, start with the furthest hole (softest setting).
Good luck.
ramey
Good luck.
ramey
Sounds great! I'm in the middle of moving this week and then I'm out of town for a week but I will give you a call when all of that calms down and get my order in. I've been needing to replace my poly end links that have been on the car for awhile now as well, so it all sounds really good. Thanks for chiming in!
