auto cross
Don't think they do it anymore, but Rancho is where I got mine for my 80 TTA. But be advised, the 900 lb/in front bar I have (still have!) still SERIOUSLY strong, enough I fought stripping out the bolts in the frame. I had to put in starter bolts with spacers and nuts in the frame to make it solid. The little strap clamps didn't hold either, I had to use OEM bar to frame brackets.
My bars are adjustable, they can vary from 500-900 lb/in. STIFF is an understatement. Awesome is too! The nose heavy 2nd Gen F-Body needs it.
When I talked to Weber Chevrolet in St. Louis (1986?), they said the race car they had would do the same and they had to tack weld the bracket to the frame, then it was solid. I wish I knew before I started stripping things out. It gave me a lot of headaches.
You should post this up in the Auto Cross section. With that said, I'd buy a Watts Link-I really want one!
Hey Jenkns. The best thing you can do is contact Sam Strano at stranoparts.com. He's your best source for parts and advice and has the hardware (i.e. trophies) to back it up. Also, Sam carries the full UMI line in case you choose a class that allows mods.
Good luck.
-- Ramey/UMI Performance
Good luck.
http://www.gmhightechperformance.com...aro/index.html
Oh, and another cool thing about autocross, you can run your car bone stock. It's amazing how much you can learn about driving just by doing. I have about 10 under my belt in a stock '82 Firebird with a 4-cyl!
Sam Strano hands down! I suggest ignoring all other recommendations. He's won several championships and lately he's been pretty much the best driver in the country beating ALL other cars. He'll set your car up to be comfortable and handle great for street and autocross.
Kleeborp the Moderator™
What should you do first? Nothing. Drive the car stock, then evaluate what you may or may not need. Unless you are a really good driver already, chances are that you'll gain more by having more seat time than spending money on stuff that may put you in classes where you won't be competitive. I have a feeling Sam may echo my thoughts.
I have to admit that MeentSS02 makes a good point if you have not done autocross before.
Learning at a lower speed improves your skills so when you add to the cars capabilities you will be much faster.
When my car was down and out I was laying waste to much better handling cars with my stock Dodge Magnum. Cars like, C5 Vettes, M Roadsters, and even a Viper was having a tough time beating it raw times.
Magnum looked like it would roll over.
Also, read the rules too, you don't want to bump into a street prepared class if you aren't ready for it. My bars moved me from F-Stock to B-Street Prepared. Whole new ball game in getting your booty whipped up on a LOT faster cars.
Have fun with the stock class, don't think it is lowly to be there, it is a ball!! Bring anything, run anything, have fun!
Ok, the guy in the 80 Pontiac Catalina with a Buick 350 should have just given up, but he and the 4 passengers (fun run) had a great time! He was faster with 5 people in the car than driver alone!!
I haven't done any AC since 1987, but the one year I did it I was having an awesome time.
