Amplified gear noise w/spohn torque arm
I recently traded my LS6 Notch for this 01 ws6, it has a M6 with strange 12 bolt, and spohn pro torque arm. When i got the car it had 4.56 gears and it was really loud whining gear noise but the rear needed to be gone over and freshened up. So i had my buddy put in the 3.73 gears, and all new bearings and seals all that stuff. So it was profesionally done. Still loud, not as loud. Is this normal? Is there any way to stop this? Its not a huge deal but if i could quiet it down that would be nice.
Kleeborp the Moderator™
Any gear noise will be amplified by the torque arm since it attaches right to the source of the noise on the rear end. Tunnel mounted torque arms remove two bushings from the equation that help damp that noise - the torque arm bushing on the tailshaft, and the transmission mount bushing attached to the cross member. That's why tunnel mounted torque arms transmit more noise into the cabin - there simply isn't anything between it and the sheet metal to damp the noise.
Either get used to it, or go back to a stock style torque arm that mounts to the tailshaft.
my buddy set it up at the shop so id have to ask him. But i just found this from strange
http://ftp.pwp.att.net/m/d/mdavies2009/misc/S60.pdf read gear noise.
Yea i have a radio to cover the sound, just wasnt sure if anyone did anything to help the sound? And going back to stock style probably not the best idea figuring im going for 1000HP
