Caliper mounting bracket bolt size??
I am doing a front brake conversion to ls1 brakes. I have everything but the bolts that mount the caliper bracket to the spindles. Can anybody tell me the bolt size so i can go get some.
Save the manuals!
Here's what I have noted for them:
GM Part Number: 18023646 (Front caliper bracket bolt)
Description: Metric Hex Cap Screw
Measurement: M12 X 35 X 1.75
Manufacturer: MNP Manufacturing Corp.
Ultimate Strength: 100 kgf/mm2
Yield Strength: 90 kgf/mm2
These bolts are very hard to find at hardware stores due to their size/shape/black oxide coating and the need for them to be made by high strength steel. You should be able to get them from any dealer fairly easily.
