Anyone fix a leaky SLP Linelock before?
So I bought a SLP Linelock off of a member here for a great deal. Everything seemed good and I still believe the actual solenoid is in working order but when I hooked everything up I could not make a good seal on the brake hose that goes from the MC to the top of the linelock, when I pumped the brakes to bleed the lines I constantly got brake fluid spraying from the top of the linelock. The hose seems flared ok but it just won't seal. The only option I see now is bending my own line and putting all new hardware on it. Anyone else have this issue?
For the time being I put the stock line back on because I did a complete rotor/ pad swap at the same time.
