? on manual brakes
Old 01-29-2012, 04:04 PM
s10pro's Avatar
Default ? on manual brakes
doing a 68 camaro ls6/4l60 car has aftermarket power disk front brakes , just got all c5 brakes with kore3 brackets was thinking of going to manual brakes to clean up fire wall. does any one use manual brakes on street car that will be a driver? and opinions if i should or should not do it? thanks kevin
Old 01-29-2012, 04:35 PM
TooManySS's's Avatar
I don't think anyone still today would use a brake system without power assist.
Unless you had powerful legs and even then I would not think one would want the extra distance it would yield.
They do make power units that use dual assist and are smaller in diameter so they don't take up all that much room and look better.
Old 01-30-2012, 10:29 AM
Save the manuals!
wssix99's Avatar
Are you going to use this as a show car? If not, you'd be taking a big step back in technology and safety to achieve the look.
Old 01-30-2012, 11:28 AM
HioSSilver's Avatar
If you get the master sized properly the only reason for power assist is if your a girl.
Quick Reply: ? on manual brakes
