strut tower torx head bolts?
I was installing my new front shocks today and naturally knowing my luck, every little thing was fighting me. So what shouldve been a two hour job turned into a 7 hour job left to be completed tomorrow. Between fighting stripped torx heads and a completely rounded out shock bolt that i speant hours chisling off, im going out guns blazing tomorrow.
My question is the two torx head bolts under the master cylinder, what are there thread sizes, both of mine stripped completely out and i'm not using them to reinstall. I want to replace them with a grade8 6point bolt so i can just use a standard wrench. I plan on putting in lowering springs soon and i dont want to fight the torx head again
not sure of the thread diameter or pitch but take em to lowes and match em up? or go to GM and get bolts like the other struts and use those, i payed less than 5 dollars for mine at GM
I went to home depot they have a little bolt match thing in the hardware section. There are several things to screw the bolt into to match the thread then a ruler to measure it. The change was worth its weight in gold
