brake rotor diameter tolerance question
Ok so I decided to put new brake rotors on my car, and when I put the rear brake rotors on the rotor was real sloppy on the the hub. So I took some measurements can someone tell me if I'll be ok with these rotors. The diameter of the hub is 2.770 inches the diameter of the rotor center hole for the hub is 2. 810 inches. Is this too much space, what is the tolerance for this?
