Strut to body mount bushing or doughnut.
Does anyone know a part number or where to get them? It the rubber ring that goes between the body and strut mount. I've been looking all over with no luck on finding them. The isolator keeps coming up, but that not it. I'm sure I'm going to end up making my own.
Yeah that's what I was going to do, but I found some. They seem useless anyway. I powder coated the mounts, and I sure that would keep them from vibrating or making any noise.
"doughnut" is throwing me off... only doughnut shaped thing I know of on the front suspension is the perch and the plastic thing that sits on the perch ... and neither of those are of or have rubber. Except the bump stop, the only rubber-ish parts aren't even actually rings. So I posted a picture to help me help you, but I'm glad you got it all figured out!
The strut/shock upper mount goes through the upper a-arm plate before mounting to the body. Between this plate and the body is a small foam rubber doughnut-looking piece that supposedly keeps water out of the shock mount but since it obviously doesnt, and serves no other purpose, its ok to just leave it out
The following users liked this post:
Ezxqzz (04-06-2024)
Since I am **** about making sure my Trans Am has the parts it is supposed to have, I am going to seek out a local bushing manufacturer and see if they can make polyurethane copies of the top rubber bushings on the upper control arm bracket. Since I am replacing the entire stock suspension on my car with BMR equivalents and other after market parts, I want to make sure that I have a bushing that I can have installed and won't ever have to touch again granted it wont rot like rubber does. Lastly I am sure General Motors had a reason for including those bushings when they designed the suspension for this vehicle and I think that it may help preserve the upper control arm bracket and prevent potential metal fatigue and flexing with hard hits such as running into deep pot holes over it's lifetime which in New York State, I find many roads in bad need of repair and boy does it rattle my car with it's failing suspension.
Last edited by Phoenix'97; 04-29-2013 at 02:47 AM. Reason: I wanted to include some more information, my apologies.
Ezxqzz (04-06-2024)
