strange shocks question
Old 05-21-2012, 01:30 AM
SF 1HOTLS1's Avatar
Default strange shocks question
So i just picked up some used shocks off a local guy, and i noticed that the strange shocks do not automatically come up / rebound after compressing them as my bilstiens would. i press the strange shock all the way down and it stays down unless i pull it back up. is that how these shocks are?
and also, when comparing my eibach rear coil springs to my stock rear coil springs i noticed the eibachs are a lot more softer then the stocks. the stocks are a bit firmer. i hear people say use the stock coil springs in the rear for drag racing but wouldnt u want a softer coil spring in the rear? so shouldnt i just leave the eibachs in?
Old 05-21-2012, 07:23 AM
UMI Sales's Avatar
A gas charged shock will extend due to the pressure in the shock. A standard shock stays where you put it. So, no worries there.
Do you know which Eibach spring you have?
Old 05-21-2012, 10:38 AM
SF 1HOTLS1's Avatar
yes they are the eibach prokits.
Old 05-21-2012, 12:07 PM
01ssreda4's Avatar
My SLP Eibachs are soft as well. Car hooks great on them.
Old 09-27-2012, 02:36 AM
Vetal's Avatar
Guys I need urgent help... Top "stud" (black one) on one of my Strange SA shocks broke when I torqued down spring mount (about 37lbs). What is the thread size on the shock shaft? Looks like 9/16 18TPI, ciould that be correct? I'm not that good into US thread sizes...
Quick Reply: strange shocks question
