poly/roto LCA vs Stock LCA with 1LE bushings
I'm deciding between these two ways to go so I need someone to make my mind up. I already have the 1LE bushings and relocation brackets paid for. If I go with the poly/roto combo is it worth the extra $100-200 for a set? What kind of differences will I see here?
Suspension is SLP bilstein/eibachs all around, 275/40/17s summer tire all around. rest of the rear suspension is stock, front has 32'' 1LE swaybar and poly endlinks.
We specify Roto-Joints anytime we want more articulation ability [defined as one wheel in bump and one wheel in rebound, i.e. during body roll]. A secondary benefit is less deflection than poly which further tightens the suspension. In much the same way poly is an upgrade from rubber, Delrin is an upgrade from poly.
Rubber, or course, gives the best damping and quietness but at the expense of performance. Delrin transfers more road noise (but not as much as rod ends) but with virtually zero deflection.
So, for the extra $ you get a suspension component which articulates very smoothly with none of the binding associated with poly. For drag cars where the rear suspension moves relatively equally, articulation becomes less important. For a corner carver, it's nice to have that smooth articulation and predictability which comes from the Roto-Joint.
ramey
