Rear coilovers on 1994 fbody
I bought a set of coilovers, LG motorsports G2 front and rear. The fronts come with all I need It looks like. The rears Im a bit lost on.
How do I install them? my car is pretty much stock suspension except for pavlock LCA/panhard, now these are going on to lower it. Its a stock 3.23 10 bolt too.
I cant find much on installing rear coilovers. I assumed they bolted in to the factory shock mount, But then I started wondering about the rear coil springs. Do those come out and nothing goes back in?
Any eye opening help is appreciated.
Maybe you can get some information from my thread ... https://ls1tech.com/forums/drag-raci...2-step-ll.html.
You may want to be sure that the lower mounts are a two-bolt design for added strength. I have read posts where some have heard of breaking a one-bolt lower mount. The installation instructions for my Strange coil overs showed bolting directly to the upper shock tower which is how I installed mine. No plates!
