will Corvette C5, Z06,rotors fit a t/a
hi, i wanted to see if anyone knew if the Corvette C5, Z06,brakes will fit on a 02 T/A???basically for know i wanted to see if i could put the rotors and pads on my T/A and then when i have more funds put vette calipers on. any info would be appreciated.
thanks,mike
thanks,mike
The answer is no, not without relocating the calipers.
Search for C-5 front brake conversion. You will need to take a sawz-all and cut the lower caliper 'ear' off your TA spindles, there is no going back after that, get relocation brackets, C-5 rotors and C-5 calipers. The relocation brackets move the caliper out farther so the rotors will fit.
And then you will need 17 inch wheels in order to clear the rotors.
https://ls1tech.com/forums/lt1-lt4-m...e-upgrade.html
If you're going to be doing road racing or the like, maybe a big brake upgrade is a good fit, but chances are a well set-up C5 conversion will probably not even be used to it's full potential by most drivers.
