HELP! How to adjust HAL springs?
Old 04-01-2004, 09:20 PM
Deividas93GT's Avatar
Default HELP! How to adjust HAL springs?
I have the HAL QA1 springs and I was wondering how you can adjust them? The car sits WAY to low right now and the headers are all banged up. (Will have to get new ones ) It looks like we need a special wrench to turn the black things that the spring sits on. How do we do it?
Please help!
Old 04-02-2004, 02:50 AM
jfm
jfm's Avatar
You need a spanner wrench to adjust them.It is a PITA to raise them,take your time.
BTW,I know this is a bit late to help you but when you install Hal front springs I would set them an inch higher than stock because over a couple days they will drop down.It is a lot easier to lower them then raise them,my adjustment rings are almost stripped.
Old 04-02-2004, 08:13 AM
Where can I get that spanner wrench? Is there a way to unload the spring so it would be easier to turn that wrench? Like lower the a-arm?
Thanks
Old 04-03-2004, 01:17 AM
98sspullin'em's Avatar
its is a lot better if your have the bearing kit on it, it would have been 20 bucks more all together and its a hell of a lot eaiser... thats what im gonna get!!
Old 04-03-2004, 08:26 AM
I did it yesterday with a spanner wrench. Lubed the bottom of the spring and that made things much easier. Now it sits perfect
Thanks
