Tick master cylinder
For those running the tick master cylinder, did you use longer bolts then supplied, they look short and made out of regular steel which could be a problem down the road since its into aluminum threads.
Also does anyone have pic of the clutch hose routings under the heat sheilds. Iam not sure if the hose should go under the shield which is attached to the frame (verticle).
