Steering slop?
Old 06-23-2013, 03:18 PM
pHEnomIC's Avatar
Default Steering slop?
I have some slop in my steering. I can wiggle the wheel quite a bit back and forth and have no input to the wheels. I appears that the u joint moves fine and the bearings/hubs dont wiggle excessively. What can I do to narrow it down?
Is it the rack or tierod ends?
Old 06-27-2013, 12:27 AM
nascarnate326's Avatar
I would put the car on jack stands and then try to move the steering wheel. If it moves like it should then its some kind of bearing.
I taped a hot dog roasting stick to my steering shaft and just moved the steering wheel slightly, verifying that the shaft was doing what the wheel did.
I made the mistake of replacing the rack before I did enough testing, turns out my LT1 ragjoint on the steering shaft was junk. Replaced with solid LS unit and havnt had issues since.
Old 06-27-2013, 12:36 AM
96LT1Z's Avatar
Rag joint
Old 06-27-2013, 07:00 AM
leadfoot4's Avatar
What year is the car? How many miles on it?
Originally Posted by 96LT1Z
Rag joint
Only if it's an LT1 car, I believe. As far as I know, when GM switched to the LS engines, they changed the steering shaft, and the newer one doesn't have the rag joint.
Old 06-28-2013, 01:03 AM
96LT1Z's Avatar
Only if it's an LT1 car, I believe. As far as I know, when GM switched to the LS engines, they changed the steering shaft, and the newer one doesn't have the rag joint.[/QUOTE]
Old 07-29-2013, 10:18 PM
pHEnomIC's Avatar
Turns out the lower screw on the steering shaft became loose. Threw some loctite and retorqued it, good to go!
Quick Reply: Steering slop?
