Rear End Wobble?
Old 06-25-2013, 02:26 PM
bouttime's Avatar
Default Rear End Wobble?
Dyno yesterday we noticed the rear looked to be wobbling. By "wobbling" I mean tire rotating unevenly on both sides. I just had lots of new parts installed including: 9inch shortened 3 inches each side, new driveshaft, torque arm, lca's, panhard, new rotors and pads from brake motive, custom boze wheels, qa1 coilovers front and rear. Does anyone know of any particular part that would cause this problem, other than the obvious reason of re-torquing the wheels back on the car to make sure they are flush? I pick the car up tomorrow so any feedback is appreciated thanks
Old 06-25-2013, 03:04 PM
Awake455's Avatar
Pop the rotors and calipers back off, check the axle flanges for runout. Wouldn't be the first set of axles that did not run true right out of the box.
Quick Reply: Rear End Wobble?
