Squeaking from front end sitting still
Old 08-17-2013, 02:59 AM
383partout's Avatar
Default Squeaking from front end sitting still
97z28 30th anniversary m6 full bolt ons full aftermarket UMI suspension and lowered on BMR Springs & Bilsteins.
When sitting still if I turn the wheel left/right I get a squeak that sounds like the tire rubbing on something, but I've checked clearance and nothing is rubbing at all or is even close to it. It's like a rubber on metal sound, what else could this be?
Old 08-17-2013, 03:31 AM
Decadence75's Avatar
If you're running poly bushings on that aftermarket suspension and they have not been greased regularly then it will cause a squeak.
Quick Reply: Squeaking from front end sitting still
