2010 Camaro Brembo Brakes Master Cylinder
Old 11-20-2013, 11:15 AM
ryanater's Avatar
Default 2010 Camaro Brembo Brakes Master Cylinder
Can anyone that has done the 14" Camaro SS Brembo swap let me know if a new master cylinder is recommended after making the swap? Does the pedal require noticeably more travel to get the brakes to grab?
Input from people who have made the swap on all 4 corners is especially appreciated since I am looking into converting the rears as well. (I am running C-clip eliminators, so pad knockback shouldn’t be an issue)
Old 11-20-2013, 08:02 PM
andysc's Avatar
I'm getting ready to do mine, but from what I have read, you do not need to change master cylinders, and braking is much improved with no fading. I 'll let you know once I am done and have tested it out.
tia
andy schuck
Quick Reply: 2010 Camaro Brembo Brakes Master Cylinder
