LCA relos with SFCs that bolt thru LCA?
Old 12-01-2013, 08:03 PM
dirt.bike.mike's Avatar
Default LCA relos with SFCs that bolt thru LCA?
I just purchased the Spohn weld in SFCs that mount with bolt thru the LCA. Will I still be able to get relocation brackets on there?
Old 12-01-2013, 08:40 PM
scj
scj's Avatar
Considering the subframe connectors are on the body side of the lower control arm, and the relocation brackets weld or bolt on the axle side of the lower control arms. You're in the clear! if you're having interference with the two, it's user error.
Old 12-01-2013, 08:47 PM
QuicksterZ's Avatar
Pm sent
Old 12-01-2013, 10:10 PM
Badazz 97 TA's Avatar
relocation brackets bolt/weld onto the axle, subframes and Lca's bolt to the body side.
Old 12-02-2013, 06:02 PM
thanks for the responses. Newbies, gosh! Didn't wanna just buy parts and then see if it all bolted together. figured there wouldn't be problem, just checking. thanks guys
Quick Reply: LCA relos with SFCs that bolt thru LCA?
