Parking brake rubber boot question
I replaced my rear rotors/pads and noticed the parking brake rubber boots on both sides were deteriorated. I got OEM boots from a member on here and looking to install them.
What's the simplest way to get the parking brake cables off the lever so I can slip the new boot on? It looks like I could remove the two rear cables from where it attaches to the front cable, but wanted to see if there's a better way.
Disregard this. I now see how the parking brake cable in the rear detaches from the bracket and then there's enough slack to unhook it from the lever.
wssix, In my case, for both sides I needed to remove the cable from the rearmost bracket (using screwdriver to compress the retainer fingers, then it pushes through and can be removed). In addition, on the driver side, the plastic cable tie needed to be cut and on passenger side the metal hanger bracket removed. Then there's plenty of slack to remove the cable from lever.
Save the manuals!
Nice to know. Did the tension release on one side when you unhooked the brackets, etc.? Or did you have to do both sides at once for the tension to go down?
I've always been afraid to mess with those plastic retainers in fear that I'd break one and not be able to find a replacement part.
